Hi. I've been planning to build a water cooling loop, then I saw this:
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_202_972&products_id=34962
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_202_972&products_id=33590
The difference between the 2 is one has pump/res combination and the other one has separated XSPC D5 pump and reservoir. I did some research and know that the D5 can pump 1200 lph while the other one can only pump 750 lph.
First (1) thing I wanna ask is that the pump + 1 more fan (the cheaper one has only 2 fans) worth an extra $100?
If you scroll down, you see they let you choose XSPC Raystorm - Intel, XSPC Raystorm - Intel(Copper) or XSPC Raystorm - Intel(Chrome)
(2) Do Copper and Chrome perform much better? If it's not Chrome nor Copper, what else is it? And is Copper or Chrome worth extra $45?
On this one: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=59_202_972&products_id=33590 . Scroll down and you'll see "Radiator Accessories". (3) Do these shrouds and boxes make a difference in cooling performance?
That's it. Thank you guys in advance for input
