Hello forums i just applied to this forum although i have been a lurker for quite some time.
OK its time i get to the meat of the situation im building a pc for extreme gaming for long hours ( 8 hrs+) im trying tho keep this rig in the $2000 range as i cant afford anything more and im choosing an amd build which i think makes alot of difference in my budget.
Expectations: intense gamin and im not planning on updating every couple of months i want this rig to last atleast three year where it
can perform quite well as newer games are released.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, surfing the net, video editing and intro creation
PARTS NOT REQUIRED: mouse, monitor, speakers, OS
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
PARTS PREFERENCES: Asus ,saphire
OVERCLOCKING: Yes to 4.0 ghz
MONITOR RESOLUTION: 1920x1080 a 23 inch samsung lcd
ADDITIONAL COMMENTS: quiet not really i use headphones and must be able to take a pounding cause i love maxing out games and i play very very long hours
mobo: ASUS Crosshair IV Formula AM3 AMD 890FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Prod [...] 6813131644
GPU: SAPPHIRE Vapor-X 100281VX-2SR Radeon HD 5870 1GB 256-bit GDDR5
http://www.newegg.com/Product/Prod [...] 6814102872
CPU: AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz Socket AM3 125W Six-Core
http://www.newegg.com/Product/Prod [...] 6819103849
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Prod [...] 6820231277
Storage#1: Intel X25-M Mainstream SSDSA2M160G2XXX 2.5" 160GB (for boot drive and for games)
http://www.newegg.com/Product/Prod [...] 6820167017
#2: western digital caviar black 640 gb (for other applications and stuff)
http://www.newegg.com/Product/Prod [...] 6822136319
cooling: Noctua NH-D14 120mm & 140mm SSO CPU Cooler
http://www.newegg.com/Product/Prod [...] 6835608018
case: COOLER MASTER Storm Scout SGC-2000-KKN1-GP Black Steel / Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811119196
PSU: CORSAIR HX Series CMPSU-750HX 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready
http://www.newegg.com/Product/Prod [...] 6817139010
Optical drive: LG 22X DVD±R DVD Burner Black IDE Model GH22NP20 - OEM
http://www.newegg.com/Product/Prod [...] 6827136144
i was thinking of getting a 5970 but i just cant bring myself to spend that much on a gpu right now $700 is just too high
will this setup last 3 years or so because im planning to add things like Ram and maybe another gpu when my card starts to age.
well the cooler i chose the noctua because im planning to push my cpu to 4.0ghz is this a good choice because i dont really like water cooling because its just too risky and expensive.
is this spending too much any ideas for lower cost and same performance?
Reason of edit: just adding a few things and changing the format
