Need help chosing parts for new build.
My uncle wants a new computer for as cheap as possible and I said I would build him one which I have done before. Only thing he needs now is the tower. I chose the parts and want feedback if I picked the right parts. Every part has a 4 or 5 star rating so they should be fine but I want to know if there is any improvements that can be made.
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811154094
PSU
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4252524&CatId=1077
MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157173
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116264
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211066
Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148451
Optical Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151193
SATA Cable
http://www.newegg.com/Product/Product.aspx?Item=N82E16812816032
Is this a good set up?
4 answers Last reply
More about need chosing parts build
  1. No it's horrible. Look above on the forum for the guide on posting build questions and we'll be able to help you out a lot better
  2. Not good at all. Ditch the PSU and look for Antec, corsair, pc power and cooling, silver stone, and ocz for quality PSU's. For $300 budget your going to get a pretty much crap PC.
    By the way, that psu is horrible. Don't use it whatever you do.
    He doesn't do any gaming? Here's $295 after $25 MIR.
    To be honest, that's about as cheap as its going to get... You can take out a ram stick if you want.
  3. I 2nd that build, much better.
  4. Thanks and no he doesn't do any gaming. He just needs a home pc. Thanks for the help
New Build Computer New Build Systems Product
