I am "trying" to select a system and I am painfully struggling with the following choices. I have a hard-budget and option 1 is my max+.
1. i7-930 (2.80GHz) + [Corsair] 256GB SSD (+$200 US)
2. i7-975 Extreme (3.33GHz) + [WD] RAID 1 SATA III/(2X)1TB HHD/64MB Cache /7200 RPM
Obviously, I realize the SSD drive is faster than the HHD but so is the CPU in the above. Yes, I prefer RAID 1 "peace of mind" - this system is used in my day to day life (I will never RAID 0 a HDD). My thoughts are once the initial application + data is loaded it is all about CPU, but Filemaker Pro is about Disk + CPU.
However, for example I run Filemaker Pro with *HUGE* (6 GB+ - textual ; 18-60 related record files) records Millions of records and the some relational searches take 5+ minutes and a weekly data output that can take several hours to process. The non-indexable relational searches are what bothers me the most.
THANK YOU VERY MUCH!!!
Basic build info:
MOBO GigaByte GA-X58A-UD3R w/ SATA III+RAID
RAM 6GB (2GBx3) DDR3/1600MHz Triple Channel Corsair Dominator
Basic build info:
