Running a laptop with XP Pro. after powering up I use teh Ctrl / Alt /Del to get to a login screen and it has a user name, domain and password. I got into it fine. I needed to add Windows Network for WorkGroup to connect to an office network and I set that up without using the "don't have an office domain" It needed to restart o activate things. Now the Login Screen only indiactes User ID 7 Password and not the previous domain that had appeared and it won't accpet the password that I know is correct. Can't seem to star in safe mode (with or without network access) to go in and try and reset things.
Any ideas of a soultion would be appreciated.
Angus
Angus
