Replacement CPU/Mobo help
Last response: in Systems
My wife has been using my old gaming rig and it died a few weeks ago. It will not post and I get no beeps from the mobo. I have tried swapping out the ram with no luck. I am assuming it is either the mobo or cpu. I figured I could just get a new cpu/mobo combo and reuse the rest of the parts. She primarily uses the PC for scrapbooking, internet and basic games (Plants v. Zombies, etc). Trying to keep it as reasonable as possible I was think about the Athlon II X3 440 which newegg has for $84. It has 2-250gb hard drives that are in raid that I will probably yank out of raid and just run 500gb of storage. Here are the rest of the parts I would like to reuse:
• 2 x 2048MB Corsair™ XMS2 DDR2-800
• 512MB eVGA™ NVIDIA® GeForce™ 9800 GT
• 2 x 250GB Western Digital WD2500JD 7200rpm SATA/150, 8MB Cache - RAID 0 Stripe (500GB Total)
• 550 Watt Antec® TRUE POWER 2.0 Quiet Power Supply
• 16x Lite On® DVD+/-RW/CD-RW Dual Layer
• 16x DVD/48x CD-RW Lite On® Combo Drive
So, which mobo would be best around $100 and am I over-looking any compatibility issues? I doubt I will OC at all or minor OCing at the most. Thanks for any advice in advance.
More about : replacement cpu mobo
This motherboard SHOULD work(from what i've looked, I may be wrong). It's compatible with DDR2-800, has a PCIe 2.0x16 slot(9800GT), SATA RAID 0/1/5/10/JBOD. I think this is good. It's also AM3 CPU compatible so you can use the Athlon II X3 440. The mobo can also unlock the 4th core, and maybe unlock L3 cache(Something i'm not really familiar with).
So all in all, this mobo will get the job done for a regular casual computer.
Not a bad offer on the 620. That may be the way to go.
As for the other suggestion, I have never heard of the ASROCK. Are the any good? I tend to lean towards Asus, Giga or MSI.
Ask the community
