Qty. Image Product Description Unit Price Savings Total Price
Update14-133-266 PNY VCGGTS2501XPB GeForce GTS 250 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card - Retail
Model #:VCGGTS2501XPB
Item #:N82E16814133266
Return Policy:VGA Replacement Only Return Policy
In Stock
Mail in Rebate14-133-266
Note (Add14-133-266)
Save Cancel $149.99 $149.99
Update11-129-066 Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case - Retail
Model #:Three Hundred Illusi
Item #:N82E16811129066
Return Policy:Limited Replacement Only Return Policy
In Stock
Note (Add11-129-066)
Save Cancel $69.99 $69.99
Update17-182-199 Rosewill Green Series RG530-S12 530W Continuous @40°C, 80 PLUS Certified, Single 12V Rail, Active PFC "Compatible with Core ... - Retail
Model #:RG530-S12
Item #:N82E16817182199
Return Policy:Standard Return Policy
In Stock
Note (Add17-182-199)
Save Cancel $74.99 -$25.00 Instant $49.99
Update12-270-093 BYTECC 18" Serial ATA-150/300 Cable w/Locking Latch Model SATA-118C - Retail
Model #:SATA-118C
Item #:N82E16812270093
In Stock
Note (Add12-270-093)
Save Cancel $2.89 $2.89
Update13-128-435 GIGABYTE GA-890GPA-UD3H AM3 AMD 890GX SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard - Retail
Model #:GA-890GPA-UD3H
Item #:N82E16813128435
In Stock
Note (Add13-128-435)
Save Cancel $139.99 $139.99
Update19-103-808 AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGMBOX - Retail
Model #:HDZ955FBGMBOX
Item #:N82E16819103808
Return Policy:CPU Replacement Only Return Policy
In Stock
Note (Add19-103-808)
Save Cancel $159.99 $159.99
Update20-231-303 G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRM - Retail
Model #:F3-12800CL7D-4GBRM
Item #:N82E16820231303
Return Policy:Memory Standard Return Policy
In Stock
Note (Add20-231-303)
Save Cancel $114.99 $114.99
Update20-300-608 SABRENT CRW-UINB 68-in-1 USB 2.0 Internal Card Reader w/ USB 2.0 Port supports SDHC/VISTA - Retail
Model #:CRW-UINB
Item #:N82E16820300608
In Stock
Note (Add20-300-608)
Save Cancel $12.99 $12.99
Update22-152-181 SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Model #:HD502HJ
Item #:N82E16822152181
Out Of Stock
Auto-Notify 22-152-181
Note (Add22-152-181)
Save Cancel $54.99 $54.99
Update27-151-188 SAMSUNG DVD Burner Black SATA Model SH-S223L LightScribe Support - OEM
Model #:SH-S223L
Item #:N82E16827151188
In Stock
Note (Add27-151-188)
Save Cancel $26.99 $26.99
Update32-116-758 Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM
Model #:FQC-00765
Item #:N82E16832116758
Return Policy:Software Return Policy
In Stock
Note (Add32-116-758)
Update35-103-065 COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long ... - Retail
Model #:RR-B10-212P-G1
Item #:N82E16835103065
In Stock
Note (Add35-103-065)
Save Cancel $34.99 $34.99
Update35-186-020 ARCTIC COOLING MX-2 Thermal Compound - Retail
Model #:MX-2R
Item #:N82E16835186020
In Stock
Note (Add35-186-020)
Save Cancel $7.98 $7.98
Subtotal: $965.76
