All,
I'm planning to build a new system at home (my first build) and I could use some advice/help from those who use theirs in a similar manner. I'll be using it for a combination of gaming (currently Star Wars Galaxies but will change to Star Wars: The Old Republic when it comes out) and for 3D modeling using SolidWorks 2009. The following is my basic info:
BUDGET: $1200 MAX
APPROXIMATE PURCHASE DATE: 30-60 days
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming and Solid modeling
PARTS NOT REQUIRED: mouse, keyboard, monitors
PREFERRED WEBSITE(S) FOR PARTS: Newegg or Amazon
PARTS PREFERENCES: Intel CPU, I'm open on all other parts
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: 1680 x 1050
ADDITIONAL COMMENTS: quiet is good, low heat signature (it's going to be in a cubby in my desk), tower or mid-tower form factor
I've selected most of the items that I thought we be a good fit for my use but could use advice.
CPU: Intel Q9550
MOBO: Gigabyte GA-EP45-UD3P
RAM: Mushkin Enhanced Blackline Ascent 4gb x2
HD: WD Caviar Black 1TB
PSU: Thermaltake W0117RU
Case: NZXT LEXA Blackline
CPU Fan: suggestions (if needed)
DVD: suggestions with LiteScribe technology
GPU: suggestions, currently using a Geforce 8800GTS most of the time but I also have a Quadro FX570, the 8800 is great for the gaming but lousy for modeling, the FX570 is ok for modeling and lousy for gaming.
BUDGET: $1200 MAX
OVERCLOCKING: Maybe
CPU: Intel Q9550
