Is there a consensus on mixing fans in a case?
There is nothing to stop you but if you are planning on connecting them to a single connector make sure they don't go over the rated current for that connection
In my opinion which I'm aware you didn't ask for lol I don't think adding another fan is going to improve the temperature significantly maybe 1-2 degrees if your lucky but hey you should test temps without the extra fan and then with the fan and let us know just out of curiosity
