XP-SP2 Desktop display problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
Hello you friendly helpers.
I'm running WIN-XP/SP2
My desktop has suddenly changed. On the left side of my 17" display. I have
a 3" column wich looks the column you see in a folder. On the top "Folder
Tasks" followed by "Other Places" and "Details". I have tried to get rid of
it, no luck. Windows "Help" of course, is no help. I can not right click on
it to get properties.
I would really appreciate, if anyone can help me.
Thanks very much in advance
G
Guest
Guest
Hi manmeil0815,
There is surely a fix for this issue. Before that, can you post the contents of this registry key?
[HKCR\CLSID\{00021400-0000-0000-C000-000000000046}\shellex\ExtShellFolderViews]
Click Start/Run and type REGEDIT to access the Registry Editor. Navigate to the above path and then use the File, Export option to save to REG file. Open the REG file with Notepad and paste the contents here.
Ramesh, Microsoft MVP
Windows XP Shell/User
http://windowsxp.mvps.org
"manmeil0815" <manmeil0815@rogers.com> wrote in message news:r4SdnYG55ODMtyjcRVn-iQ@rogers.com...
G
Guest
Guest
Thank you very kindly for terrific response.
Here is the contend of the RegKey.
I hope I got this right
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\CLSID\{00021401-0000-0000-C000-000000000046}\shellex\MayC
hangeDefaultMenu]
Thanks again
"Ramesh [MVP]" <ramesh@nojunkmails.com@mvps.org> wrote in message
news:%23eCVqKC3EHA.4004@tk2msftngp13.phx.gbl...
Hi manmeil0815,
ws]
G
Guest
Guest
Pls export this key: {00021400-0000-0000-C000-000000000046}
Not: {00021401-0000-0000-C000-000000000046}
"manmeil0815" <manmeil0815@rogers.com> wrote in message news:_9idnTAunfM-aijcRVn-3w@rogers.com...
hangeDefaultMenu]
Thanks again
Hi manmeil0815,
ws]
G
Guest
Guest
Please excuse my gray hair. :)
[HKEY_CLASSES_ROOT\CLSID\{00021400-0000-0000-C000-000000000046}\shellex\ExtS
hellFolderViews]
news:OJPBzuI3EHA.3756@TK2MSFTNGP14.phx.gbl...
hangeDefaultMenu]
Thanks again
Hi manmeil0815,
ws]
G
Guest
Guest
hellFolderViews]
Thanks again
hangeDefaultMenu]
Thanks again
Hi manmeil0815,
ws]
G
Guest
Guest
I assume there are no sub-folders, values (in the right-pane)?
To fix this, click Start/Run and type this command:
regsvr32 /i shell32.dll
-or-
Fix from Doug Knox:
http://www.dougknox.com/xp/scripts_desc/xp_commtask_desktop.htm
"manmeil0815" <manmeil0815@rogers.com> wrote in message news:Oc2dna_SYO6_gSvcRVn-jw@rogers.com...
hellFolderViews]
Thanks again
hangeDefaultMenu]
Thanks again
Hi manmeil0815,
ws]
G
Guest
Guest
Dear Ramesh,
Thank You very much indeed.
You are a true life saver.
Everythings working fine.
Thanks again and all the best to you.
Manfred
news:edYNaAO3EHA.3840@tk2msftngp13.phx.gbl...
-or-
Fix from Doug Knox:
hellFolderViews]
Thanks again
hangeDefaultMenu]
Thanks again
Hi manmeil0815,
ws]
G
Guest
Guest
YW, Manfred. Thanks for the feedback.
"manmeil0815" <manmeil0815@rogers.com> wrote in message news:TZudnRoTS9Q0wCrcRVn-2g@rogers.com...
Dear Ramesh,
Manfred
-or-
Fix from Doug Knox:
hellFolderViews]
Thanks again
hangeDefaultMenu]
Thanks again
Hi manmeil0815,
ws]
