Need a i7 build help
APPROXIMATE PURCHASE DATE: nxt month
BUDGET RANGE: $1200
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT:
-rendering(sketchup)
-Photo editing, (adobe cs4)
-MILD gaming.( Batman arkham asylum 2)
PARTS NOT REQUIRED: monitor keyboard mouse
PREFERRED WEBSITE(S) FOR PARTS: newegg.com,
COUNTRY OF ORIGIN: doesn't matter
PARTS PREFERENCES: intel, asus
OVERCLOCKING: Not right now, maybe in the future
SLI OR CROSSFIRE: maybe in the future
in this build i would want this proccesor and mobo
ASUS P6X58D Premium LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131614
Intel Core i7-930 2.8GHz 8MB L3 Cache LGA 1366 Quad-Core Desktop Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225
please help me choose the other specs. i want it to be below 1200 or 1200 ..
7 answers Last reply
More about need build help
  1. case: element g, haf 922, antec 902 depending on youpreference but the choice is very large here
    psu: corsair 750 is pretty cheap and very high quality
    mobo: I would go for a cheaper one since the one you mentioned is kind of overkill but it's your choice obviously
    GPU: 5850 or 5870 (maybe the new nvidia ones coming out are also an option)
    ram: any 6gb kit with low lattencies if you don't wish to overclock your system otherwise a 1600 ramkit would be better
    hdd: WD caviar black 640gb is very fast and pretty cheap you can go in raid0 if you wish for more speed
    when u said about a cheaper one.
    can this be?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423
    is it ok?
  3. Yes it's definetly good enough but if you want asus(which I prefer aswell) you could go with this one
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131386&cm_re=asus_p6t-_-13-131-386-_-Product
    or
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359&cm_re=asus_p6t-_-13-131-359-_-Product
    or
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131365&cm_re=asus_p6t-_-13-131-365-_-Product
    these are enthousiast boards while the one you mentioned is'nt so much.
    the first one is comparable to the Gigabyte you mentioned (only prettier :p)
    and has a pcie slot more.
    and the other two are better and much better. but this doesn't really affect performance a lot it just has more features.
  4. Samsung Spinpoint F3 1TB > WD Black
  5. I must disagree on that one. The f3 might be cheaper and faster in some aspects but it's slower in many aswell.
    http://www.bit-tech.net/hardware/storage/2009/10/06/samsung-spinpoint-f3-1tb-review/1
  6. +1^well yeah, about the mobo. p6t are more expensive. and i doesnt have usb 3 and sata 6gb. does all lga1366 socket support the upcoming 6core proccesor? i maybe going with the gigabyte mobo
    http://www.harddrivebenchmark.net/common_drives.html
New Build Intel Systems Product
