Solved
SSD reading/writing at half speed
It's a Samsung PM 810 (basically a Dell only version of the 470)
I popped it in my EEE PC 1005HAB and thought it was working great, until I benched it and saw it's running half as fast as it should.
I'm almost positive my board supports SATA II, and the drive itself is SATA II, so why would it be running at SATA speeds?
I'm clueless.
Here's my benchmark:
http://cdn.overclock.net/5/55/55fe3608_LFhlT.png
Here's a benchmark of someone else's exact drive in another system:
http://cdn.overclock.net/4/41/493x494px-LL-419ed22a_yT6JV.jpeg
Crystal Disk shows it is connected @ SATA/300 (SATA II)
So what gives, any ideas?
5 answers Last reply Best Answer
More about reading writing half speed
  1. SASTII 3Gbit supports 250MB/s and SATAIII 6 Gbit supports 500 MB/s read/write speeds.
    Also Laptop' benchmark is tend to be lower than Desktop PC.
    Do you do tweak your SSD following this Useful SSD Articles Part 2
    http://www.tomshardware.com/forum/270102-32-useful-articles-part
  2. i suppose that could be, but i installed an intel gui and it is showing the drive is running @ 1.5gb/s. so it is definitely running @ sata i speeds.
    is there a known way to verify my system supports sata ii?
  3. Best answer
  4. Best answer selected by skanndelua.
  5. you're absolutely right, i had just found that also. strange because i had read the 1005HA is SATA II, while i guess the HAB is NOT. bummer!
    was it even worth getting an SSD then?
SSD SATA Benchmark Storage
