Power for HD 5870
I was wondering, Im gonna get an HD 5870 but it says that you need 2 6 pin power connectors. My PSU is 750W so has enough juice but i only have one 6 pin connector. The HD 5870 comes with adapters, are they ok to use will it still work alright??? i'v heard not.
thanks.
jon
2 answers Last reply
More about power 5870
  1. what would be the point in creating the adapter and shipping it with the video card if it did not work? it's just power, if you're power supply can supply enough power it will, regardless of if you use the adapter or not...
    Answer is yes, it will/should work.
  2. yea cool thats what im thinking. just a tad tentative. expensive kit. heh.
    thanks
Graphics Cards HD Power Graphics
