So I ve searched a lot to Fix this problem but I havent found any fix for any of the guys out there with this.
First Im using WINDOWS 7 X64
I m sure a lot of you have heard of this before, I have 4gb but 2gb are Hardware Reserved.
What this means is that even though 4gb are installed and task manager can see that , I can only use 2.
Bios says that my total memory is 2GB as well.
If I go to Task Manager -> Resource monitor I can see that I have 2gb Hardware reserved for bios and some drivers for other peripherals.
I ve tried to do some things, here's the list .
Yes, I ve changed my memories even though they were on the correct slots.
Yes, I ve tried msconfig ->boot-> advanced settings and Maximum Memory was not ticked.
Here is my system.... If you dont want a lot of details please scroll down to see my ram my cpu and my motherboard.
MEMORY :
Device Locator Slot 1
Manufacturer A-Data Technology
Capacity 2048 MBytes
Memory Type DDR3 (PC3-10700)
Speed 667 MHz (DDR3 1333)
Supported Frequencies 381.0 MHz, 457.1 MHz, 533.3 MHz, 609.5 MHz, 685.7 MHz
EPP SPD Support No
XMP SPD Support No
Device Locator Slot 2
EPP SPD Support No
XMP SPD Support No
Both on 1.5volt if someone asks btw. They are the same Memory sticks.
CPU
CPU #1 Intel Core i7 950
CPU Name Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
CPU Code Name Bloomfield
Vendor GenuineIntel
Number of Bits 64
Instruction Set MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, ET64, XD, VMX, EST
Platform Name Socket 1366 LGA
MOTHERBOARD
Manufacturer Gigabyte Technology Co., Ltd.
Model X58A-UD3R
Version x.x
North Bridge Intel X58 Revision 13
South Bridge Intel 82801JR (ICH10R) Revision 13
CPU Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
Cpu Socket Socket 1366 LGA
System Slots 1 PCI
Memory Summary
Maximum Capacity 49152 MBytes
Maximum Memory Module Size 1024 MBytes
Memory Slots 6
Error Correction None
To sum Up.
Memory:
2sticks of 2GB ram . Model is DDR3 (PC3-10700)
CPU :
Intel Core i7 950
Motherboard:
Model X58A-UD3R
Now you guys HAVE to check this out on .. Maximum Memory Module Size = 1024. Does that mean That I can ONLY use 1gb in one slot??
If you need any more info pls tell me. I called the company that sold me the PC and what they say is that " Yes that 2gb Hardware reserved is supposed to be there" . Im pretty sure they re lying though, cause a lot of people have this kind of problem.
MEMORY :
EPP SPD Support No
XMP SPD Support No
EPP SPD Support No
XMP SPD Support No
CPU
Vendor GenuineIntel
Number of Bits 64
MOTHERBOARD
Model X58A-UD3R
Version x.x
System Slots 1 PCI
Memory Summary
Memory Slots 6
To sum Up.
Memory:
CPU :
Intel Core i7 950
Motherboard:
Model X58A-UD3R
