When trying to boot my PC, the screen never turns on. The fans are spinning, and the light on the motherboard is on (I know this doesn't mean much )
The mobo gives me 1 long – 3 short beeps which, according to the manual means no VGA is detected.
My first reaction was to try clearing to CMOS so I both removed my mobo battery for a while and also cleared it with the appropriate jumper. Is it possible that the mobo battery be out of juice after merely a year and a half of use? (bought new)
I also tried my RAM sticks one by one and in different slot, nothing helps.
After reading quite many topics on this forum, I decided to change my PSU (I had a very cheap 420w) and bought a Corsair 550W. If it didn’t help, it wouldn’t hurt to change it anyway. And indeed it did not work.
At that point decided that everything was pointing at the graphic card being defective so I went to the store and bought a new card. That did not solve the problem either.
I seem to be left with either a dead CPU or defective mobo.
I read in several places that since my motherboard still gives me some error beeps, my CPU *should* not be dead. (can anyone confirm this?)
Now, I’m thinking that the PCI-express slot is damaged somehow. I tried to look closely and noticed that one of the pin isn’t visible anymore. And also there is some residue of glue (!!!) around (and maybe inside, I can’t really see) the slot because the genius who built the PC thought it would be wise to get the card in place with glue.
I don’t have any other PC handy to test my hardware unfortunately…
Does anyone have any opinion on this?
Specs:
Mobo Asus P5QL PRO
Intel Core 2 Duo E8500
4GB DDR2 RAM 800
2 graphic cards I've tried:
-GeForce 9800GT 1gb (old)
-Asus ENGTS450 DIRECTCU TOP (brand new)
Thanks a lot in advance!
Specs:
Mobo Asus P5QL PRO
4GB DDR2 RAM 800
