Loop Drain Location
Please look at my layout and suggest a good location for a loop drain and hardware to use.
I will add the drain port in about 2 weeks when I WC my video card a EVGA GTX 670 SC 4gig(short 670) with an XSPC block
2 answers Last reply
More about loop drain location
  1. I have never liked the idea of a drain line for a closed loop system it makes it harder than it has to be try using a fill/flush system added to the loop, something like this. It allows you to direct the flow of water through a makeshift reservoir, but this is how I do things you may have a better idea. This idea will work anywhere but It works best if placed right before the pumps inlet.
    http://imageshack.us/a/img690/2857/fill002.th.jpg
    http://imageshack.us/a/img513/198/tests1baseline004.th.jpg
  2. My rule of thumb is:
    Find the lowest spot in the loop. Doesn't matter where it is, put a T or a Y in and a short hose and you are golden. Doesn't need to be complicated.
Water Cooling Hardware Graphics Cards Overclocking
