Budget of about $7000-$7500 total for the computer.
So far I've bought:
3 refurbished 30" NEC 2560 x 1600 monitors, $2200
1 Intel Core i7 980X, $1070
1 Intel X25-M G2 SSD 160GB, $470
1 Western Digital Caviar Black 1TB 64mb cache 7200 RPM HDD, $110
1 Microsoft Windows 7 Professional 64-bit OEM, $130
1 Corsair Obsidian 800D, $300
1 Silverstone Strider ST1500 power supply, $400
1 Panasonic Blu-Ray Burner, $190
That leaves around $2100-$2400 to get motherboard, memory, and graphics cards.
I'm roughly planning $350-400 for the motherboard, $400-$425 for the memory, and $1400-$1600 for the graphics cards.
Memory, I'll probably get either 12 GB Corsair Dominator 1600MHz or 6 GB Corsair Dominator GT 2000 MHz. Guess I'm just a sucker for flashy colored heat sinks.
Graphics cards, I'm thinking either dual Radeon HD 5970's or triple Nvidia Fermi 480GTX's, depending on which performs better and is actually available. Neither one is in stock online at the moment, at least as far as I can tell.
Undecided on motherboard. Some options: Gigabyte GA-X58-UD7, EVGA Classified 3-way SLI, Asus P6T6 WS Revolution, Asus P6T7 Supercomputer, Asus Rampage III Extreme.
I'll probably try to match colors with the motherboard, memory, and graphics cards as much as possible. So a consistent theme to the colors of the computer. Three of these motherboards are blue and black themes, two are red and black themes, all should (I hope) work with the processor and case I've selected.
I plan to eventually water cool the cpu and motherboard chip set with a 3x120 radiator mounted in the top of the case. I probably won't water cool the gpu's, at least for a while, due to lack of space in the case and lack of funds. Maybe in six months or so, but not any time soon.
I wouldn't mind adding in a dedicated sound card and possibly a dedicated network card. I like PhysX and would probably add in a dedicated PhysX card if I went with the Nvidia gpu solution. These extra cards would probably be things that I request from Santa Claus, not something I do for the initial build, because better graphics cards has more appeal to me than these do.
Any advice on motherboard selection would be appreciated. As for gpu selection, I'll wait and see what the Nvidia stuff looks like when it is released tomorrow.
So far I've bought:
