Asus M2N-VM-DVI motherboard - Problem with DVI port
I have a problem with my Asus M2N-VM-DVI motherboard.
The DVI port is failing. I came to this conclusion because of a blank screen on my monitor, when the DVI connector is used. When I test it with another DVI capable machine, the display does appear.
Will flashing the BIOS help? Could there be something else, beyond my means to repair?
Thanks!
1 answer Last reply
More about asus motherboard problem port
  1. How long have you had the motherboard? If the event happened all of a sudden without you making any significant changes to your BIOS, then the port is most likely shot.
Motherboards Asus DVI
