[Biostar MB] Cannot connect front panel
tecmo34
Administrator
Thanks for the larger picture but it doesn't solve the issue. The image below is for your front audio, not for the front panel as your newer images is for ( http://www.hardwaresecrets.com/fullimage.php?image=601 ). They won't work together...
Front Case Audio
tecmo34
Administrator
Now were talking.... Here is where each connector plugs into on the motherboard (reference #'s from this page: http://www.intel.com/support/motherboards/desktop/sb/cs-009016.htm )
PowerLED - Green wire plugs into #2
PowerLED - White wire plugs into # 4
H.D.D - Plugs into # 1 & # 3 with the Red wire at # 1
PowerSW - Plugs into # 6 & # 8 with the Black wire at # 6
ResetSW - Plugs into # 5 & # 7 with the Orange wire at # 7
+1 --- just plug the various separate wires into the plug connections as listed and you'll be fine !
damasvara
831
It's a standard actually. If you happen to look into the motherboard manual you'll most likely find the connection diagram... :p
But not everyone is a DIY builder. Honestly, I never remembered the connections myself. That's why I always keep a picture of it. :lol:
They'll fit with the casings left on -- if you remove them there is a slight possibility that 2 of them might touch at some point (or something could fall between them making contact between them) which could short them out - so best to leave the casing on !
