Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > GTX275 TriSLI vs 5870 Crossfire. Building New System
Forum Graphics & Displays : Graphics Cards GTX275 TriSLI vs 5870 Crossfire. Building New System
I am now definitely building a whole new system, i want it to be optimized for Crysis (Warhead), starting with the graphics cards, for which i would be willing to spend £600, the rest of the system would be built to make the most of those graphics cards in Crysis. I'm going to try and keep the rest of the machine under 300 (I stress try).
I have read that the 275GTX's scale really good, especially in Crysis.
TriSLI 285 vs Tri Xfire in Crysis:
http://benchmarkextreme.com/Articl [...] re/P4.html
The 275 only scores 1-2 FPS behind the 285 if at all behind in all the benchmarks i've seen and i've read that you can overclock a 275 to being 4-5 FPS faster than a 285, some suggesting the 285 is just a waste of money(it would cost me about 200-250 each).
ATI Radeon HD 5870 Single, Crossfire and TriFire VS GTX 285 Single, Dual and Tri Sli in Crysis Warhead:
http://benchmarkextreme.com/Articl [...] re/P3.html
The 5870 gets smoked outrageously.
I could get 3 275's for about 450-500, 2 5870's would cost about 600-650, a 5970 would cost about 500-600, Amazon UK offers them for about 420, but they are out of stock and don't know when they will get more, my guess is it will be a long time.
I'm also very skeptical of the 5870's Crysis performance there seems to be so much conflicting data, opinions and reports. I may buy one to test on my current system, just for the sake of comparison.
I could get 3 GTX 285's for about 650, but i don't think that would be any significant improvements over the 275's in Crysis.
Now for the rest of the PC i need some suggestions, not sure whether to go for an I7 or not.
I'm going to stick with Windows 7 32-bit and 2x4GB ram, not sure what speed it would need to be.
I don't know anything about matching CPU Mobo FSB speeds in overclocking and how this effect Ram choices, so i need some help there.
All my PSU needs to do is run the graphics cards, a 1000 watt PSU should be able to handle whatever option i go for, i use 1 CD drive 1 Hard Drive, i have no idea how my mobo and processor would effect power requirements.
Here is a cheap PSU:
http://cgi.ebay.co.uk/NEW-1000W-AT [...] 3a5883d81e
# Multi-GPU support independent triple +12V rails designed specially for dual/tri graphic cards
# For Socket 775; AM2 and all backward comptable CPU's; For Quad Core/ Exterme systems
Not sure if that first part is spiel or not and am not sure if the second part indicates it will only work with socket 775.
So if i went with an I7 it would not work?
Reply to Mpyra
DONT! skimp on a PSU, its extremely important to get a quality PSU (not the generic/crap PSU that you linked to)
I hope you have very deep pockets if you intend to max Crysis
If your only every going to play Crysis then I'd recommend an nVidia GPU setup.
I don't see how you plan on getting the rest of the PC for £300, which would include a case, PSU, RAM, Mobo, CPU, Aftermarket cooler, HDD, DVD Rom Drive, Fans........
I'd recommend you go for a Ci5 or Ci7 and overclock it alot to get the most out of your GPU's
Reply to omgitzfatal
- 0 +
First, I'm extremely skeptical about those benchmarks. At the very least, they were on old drivers. The 5xxx series scales great in crossfire, better than SLI or matching it. So today with newer drivers your going to see pretty linear scaling between the two.
Second, while triple GTX 275s will give you a bit more performance, they lack DX11 and the extra performance will go more or less unnoticed since you will be able to max every game with any sort of optimization. Basically there is no good reason to go with the GTX 275s because they are simply out dated, especially for your price range. Another thing to consider is that you can always add a third 5870 if they ever start struggling with games. Also, the 5870 requires much less power than a GTX 275 which will make your PSU choose easier and cheaper, more on that later. If you can wait about a month and a half, nVidia's GTX 4xx series will be out and they may provide the performance you are looking for in that price range.
As for the system, a Phenom II 965/955 will do just fine with a nice AM3 board. It is cheaper than the i7 and will give you the same performance in gaming. However, if you go the SLI route you need to go LGA 1366 since LGA 1156 is stuck with x8/x8 or x8/x4/x4 and AM3 is stuck with the horrible nightmarish nVidia chipsets, where Intel can utilize SLI on their chipsets. Also, get Windows 7 64-bit, otherwise you will have RAM and VRAM bottlenecking, not to mention that this is 2010...
As for the PSU, no that wont work. You need to look at quality brands like Corsair, Seasonic, Antec, PC Power and Cooling, or the Enermax Revolution series.], otherwise the PSU will die and take your hardware with it.
You can get away with a 750-850w for the 5870 crossfire, but you need a 1000w for the GTX 275 tri SLI.
To give you an idea of why cheap PSUs are bad, and the one you listed is terrible:
http://www.corsair.com/cinema/movie.aspx?id=622747
------------------------------ Want Rock and Metal?
Paul Online Radio Network: http://www.paulradio.net/
Reply to AMW1011
- 0 +
Budgeting, picking the best bang for buck products, i did stress try, i will spend more if i need to.
I found a nice case for 30, my current one will be too small.
I have a HDD and a DVD Drive.
The point is i want the best price for performance.
Reply to Mpyra
- 0 +
looking at the overall scores, http://www.benchmarkextreme.com/Ar [...] e/P18.html the dual 5870's are as fast as tri 285's. thats overall though. if you are just gonna play crysis then it looks like the 275's would be better, but what about crysis 2? it's probably being made on ati hardware.
Reply to nfail
- 0 +
To me the results of those benchmarks make perfect sense, as the GTX cards have better scaling in Crysis.
The 5870 wiped the floor with GTX275 in other parts of the 20 page review.
It is the only review to compare Tri SLIed GTX cards to 5870 Xfired (5970).
The other than the spectacular performance of the tri sli 285's, the review demonstrates that the GTX 285 performs way worse than a 5870
, but when slied performs the same as a 5870 xfired, which is something that's well demonstrated in other benchmarks for crysis.
http://www.tomshardware.com/review [...] 474-8.html
I'll respond to the rest of your post shortly.
Reply to Mpyra
- 0 +
nfail wrote :
looking at the overall scores, http://www.benchmarkextreme.com/Ar [...] e/P18.html the dual 5870's are as fast as tri 285's. thats overall though. if you are just gonna play crysis then it looks like the 275's would be better, but what about Crysis 2? it's probably being made on ati hardware.
I doubt it, Crytek n Nvidia are buddy buddies and seeing as Fermi is probably going to be a bust Crytek will likely optimize Crysis 2 for last generation hardware.
Remember they lost out in sales because of the system demands of the last game, they are not likely to push the envelope even further, Crysis 2 will be optimized for generation just past not generation coming.
Additionally the game is going to be ported to consoles, which is why it's expected to be less of a sandbox type game and moved to more urban environments, all this suggests Crysis 2 will not be as graphically demanding as Crysis 1 and will certainly be optimized for Nvidias already released hardware.
Overall, the 5870 xfired would probably be better, but there aren't many games out that it would make much of a difference on. 60 FPS average at 1980x1080 is good enough for me.
The GTX275's TriSLi seems to be one of the only cards capable of doing this on Crysis (maybe a 5970 Xfired could also?) and i'm pretty sure it could run any other game for the foreseeable future at that speed.
Edit: It seems doubtful that a even a 2 5970's xfired would be able to compete with a TriSLI GTX275/285 as it has markedly lower scalability in Crysis or 4 5870's Xfired for that matter.
Message quoted 3 times
Message edited by Mpyra on 03-10-2010 at 02:30:57 PM
Reply to Mpyra
- 0 +
Okay won't cheap skate on the PSU.
Also, how does a Phenom II compare to the I7 price vs performance in gaming, particularly Crysis, which i have decided to definitely run with a 275 as i just found out my HDTV TV only puts out 60hz.
So with any game in existence, 60 FPS is the most i can appreciate, or that i really can or ever will appreciate as i think the refresh rate of the human eye is about the same.
Sill there will be a lot less minimums on Crysis.
So what processor would run better with TriSLI 275's for cost vs performance?
Reply to Mpyra
Phenom II's will do you just fine most of the time and for the price vs performance, may even be a better choice at times. However with the amount of scaling to be done with Tri-SLI, I'd recommend going with a bit more powerful of a cpu, the core i7.
Make sure you get a socket 1366 also because 1156 doesn't have that many lanes of PCI Express enough to carry out what you want. Core i7 920 should be your best bet imo
Reply to uncfan_2563
- 0 +
How exactly does scaling relate to CPU processing power exactly?
I'm going to look into the i7 evaluate the cost of it's mobo options combined.
Right now I'm confident my Q6600 will be fine on a LGA775 TriSLI board like the Nvidia 780i, worst case scenario is i buy a better 775 CPU.
If the price/performance seems right to me on the i7 option i'm liable to go via that route however.
Thanks.
Reply to Mpyra
Get two 5870s, they will be able to effectively max out Crysis.
A 5970 is two underclocked 5870s that perform slightly better than two 5850s, and it was able to get an average of 45fps on 1920x1200, AA x8, and settings on very high. On higher resolutions and AA, it pulls ahead of the GTX285s to a significant degree.
Other benefits include:
1. dx11 support
2. eyefinity
3. much lower power consumption
4. runs much cooler
Message quoted 1 times
Message edited by Bluescreendeath on 03-10-2010 at 06:36:28 PM
Reply to Bluescreendeath
if you want to max crysis you gonna need least a £1500 pc
Reply to obsidian86
Thanks.
Well I'm not really the "expert" on this but I'm thinking it has something to do with the amount of data that needs to be processed and fed to the gpu's to render. If one of our more senior members can shed some more light on this topic, I'm sure the OP and I would be very happy because i'm not 100% on this either
- 0 +
1. dx11 support
2. eyefinity
4. runs much cooler
2x 5870 are 600-650
3x 275's are 450-500
I linked that benchmark chart above and it is consistent with the 2 i originally posted, the difference between 2 5970's and 2 285's is non existent without anti aliasing.
Seeing how scalable the 285's are in Crysis, i would bet that when an extra card is added the difference become negligible even with AA and non AA enabled game play would still far exceed the 5870's.
In my opinion AA on Crysis makes little difference compared to resolution and after resolution the next most important thing is that the game has good FPS.
Sadly there was no benchmarks on Crysis with AA in that review.
I going to be looking to prove that i am correct in the future if i have the opportunity however.
For now all we know is that the GTX295's are better than the 5870's without AA, with AA is anyone's guess, the massive performance gap formed when a third card was added for the 285's.
I'm not concerned with any of the first two extra's.
As for the second, i am curious as to where all the energy computers use go, it must ultimately be dissipated as and as i live in England it's often quite cold a lot of the year without heating, sometimes i use a 2kw electric heater to warm my computer room up, of course in the summer there's a chance things would get too warm.
Either way I'm not too bothered by energy usage and as for running cool, i don't think it matter if a card is hot if it performs better.
Message quoted 2 times
Message edited by Mpyra on 03-10-2010 at 07:09:36 PM
Reply to Mpyra
Mpyra, with multiple gfx cards in one system, I dont think you're going to need to turn on a heater in your room anymore xD
- 0 +
4x285's overclocked would max Crysis more than 3x275's, i just want 60 fps at 1920x1080 at the cheapest possible price.
The 3x5870's can't do this 3x275's can and for less money.
Reply to Mpyra
- 0 +
Well i hope not, that things bloody expensive :D
Reply to Mpyra
and crysis 2? performance has shown that dx11 cards wipe the floor with dx10 on level terms namely using dx11
Message edited by obsidian86 on 03-10-2010 at 07:18:15 PM
Reply to obsidian86
- 0 +
Dude, did you read the thread?
Reply to Mpyra
Mpyra wrote :
4x285's overclocked would max Crysis more than 3x275's, i just want 60 fps at 1920x1080 at the cheapest possible price. The 3x5870's can't do this 3x275's can and for less money.
It is not possible to have 4x GTX285s. The max you can have is 3 in Tri-Sli. Unless you're talking about that obscure GTX285x2 which was a novelty item priced at $1000 each.
Mpyra wrote :
2x 5870 are 600-650
There is no point in maxing out Crysis if you don't even turn AA on - without AA, the jagged lines around every surface becomes very noticeable.
In my link, the first chart showed Crysis without AA and the 2nd showed Crysis with x8 AA.
Yes the 3xGTX275s will be better in terms of raw power and price, but you're buying a last generation card.
As for running cool, it matters if your case isn't built for airflow. A card that runs hot will cause everything in your system to run hot, reducing the ability to overclock your CPU or GPU.
Anyways, if you want raw power + lowest price, you might as well get 3x4890s. They perform just as good as 3xGTX275s, and will be even cheaper still. But if you are willing to sacrifice some power and pay a bit more, you will get the advantages of the newest generation dx11 cards.
Then again, 2x or 3x 5850s is always an option.
- 0 +
Why would you even consider 3 GTX 275s? Wait for Fermi if you are going to go with NVidia.
Also 3 of them for $450-500? If you are talking about buying used cards you MIGHT be able to find 3 GTX 260s in that price range, GTX 275s are going to be considerably more, especially new($700+)
Dual HD5850s OCed to 1ghz+ will be the best deal for the money.
Message edited by jyjjy on 03-10-2010 at 07:49:51 PM
Reply to jyjjy
- 0 +
You really need to provide pictures for the AA argument and benchmarks in Crysis for the 4890's, i don't think they will scale well.
Price vs Performance in Crysis GTX275's based on all available benchmarks.
Reply to Mpyra
- 0 +
I'm talking in British pounds not dollars and your right one of the cards has been used for 4 months, but has 4 years of warranty left.
I don't think overclocking will make that much difference for the ATI cards when it comes to Crysis, the issue here seems to be scalability, overclocking the GTX 275's could exponentially increase performance.
Who knows?
I'll find out.
Reply to Mpyra
First of all, I'm not here to argue with you. You were asking for advice and suggestions, which is what we are giving. If you don't believe me or want evidence for the performance of 4890s rivaling the GTX275s, just do a quick google search.
Every one of us thus far has told you to get the 5870s. If you keep arguing against what we're recommending, then it's pretty obvious you weren't going to listen to our advice anyways.
Go ahead and get the 3xGTX275s since you're so dead set on it.
- 0 +
I thought i said earlier in the thread that i had made up my mind and was definitely going for the GTX275's, but i think that was in another thread.
In anycase, if you are going to assert something in a discussion of facts it's best to be able to back them up.
I've made it very clear i only really care about Crysis Warhead, how exactly are 3x 4970's going to rival 3xGTX275's when 3x5870's can't?
I'm talking without AA here, even with AA the jury is out.
By suggesting ATI cards would be better your contradicting my reasoning.
I'm not arguing, I'm discussing, the difference between discussion an argument is that discussion is more routed in facts and thus logic.
You not providing facts to support your emotional position is in fact indicative that you do not wish to have a discussion, but in fact want to have an argument and now your projecting that on to me.
A discussion is an informal debate and in debate it's required to supply evidence when the burden of proof falls on you, in discussion it's courteous to provide factual evidence to support your position.
I have looked at all the evidence, i don't need to Google 4890x2 Crysis performance because the single card performance falls in par with a GTX285, whereas a single 5870 card beats a GTX 285, a sli'd 285 is on par with a crossfired 5870 and finally a TriSLIed GTX85 beats a TriXfired 5870.
Your argument does not make sense and yes you are arguing, sorry lol.
Anyway, this isn't constructive, I'm more interested in processor/mobo options now.
Thanks
Edit: Oh, and i didn't know TriSLI was the maximum for Nividia cards.
As to the GTX295, they would cost £300 each, so would be cheaper than 2 5870's however i believe they are just 2 GTX260's on the same die, i have no idea how they would perform in Crysis compared to other cards, I'd suggest that they would probably have superior scaling to ATI cards, i might look into it and you must remember, popular opinion is that Crysis is a nvidia optimized game.
Thanks again.
Message edited by Mpyra on 03-10-2010 at 08:33:34 PM
Reply to Mpyra
Mpyra wrote :
I thought i said earlier in the thread that i had made up my mind and was definitely going for the GTX275's, but i think that was in another thread. In anycase, if you are going to assert something in a discussion of facts it's best to be able to back them up.
I'm talking without AA here, even with AA the jury is out.By suggesting ATI cards would be better your contradicting my reasoning.
Thanks
3x GTX275s rivaling 3x 5870s? What the hell are you talking about? Furthermore, do you know how young the 5x00 drivers are? You do realize that a single 5850 beats a single GTX285 in Crysis right?
If you knew anything about graphics cards, you'd know that a 4890 performs about equal to GTX275 in the vast majority of games. And there's no such thing as a 4890x2. Nor does two CFed 4890s fall anywhere near a single GTX285 in performance.
Why bother making this topic at all if you've had your mind set?
okini55 wrote :
I think HD 5850 crossfire should be enough of a crysis killer for anyone. But if you want to over do it then why not buy HD 5970 quadfire. 2 of those beasts can handle crysis better than anything else. Well better than anything but MARS. Thats the only GPU that can run crysis better. MARS quad SLi ftw.
Naw. 2x 5970s quad CF would still probably perform better than MARS quad SLi. 2x 5970s ~ 4x 5850s, whereas 2x MARS ~ 4x GTX285s.
Since 1x 5850 > 1x GTX285, 4x 5850s would > 4x GTX285. This is assuming the quad CF/SLi drivers are about even.
- 0 +
Isn't the mars just an overclocked 295?
Okay looking at these benchmark results:
http://www.bit-tech.net/hardware/g [...] i-review/6
Notice the 295 is about 25% faster than 2x4870.
Now look at this chart:
The same is true here, which demonstrates that this chart some form of relatability, but as alot of benchmark tests are different not the framerates you will experience with the card, but only the framerates you will experience relative to what over cards would experience.
In the Bit Tech charts Mars is about 15% better than a 295, in the toms hardware chart 2x 5870's and 2x gtx285's are about 15% faster faster than a 295.
This puts 2x5870's on par with both a Mars and Mars SLI.
Ofcourse 3x GTX 285's blow away 3x5870's.
According to their chart 2 x Mars SLI offers no improvement over 1 Mars.
You would think since 3 x gtx285's does offer about 30% better FPS than 3x 5870's (but i think real world more like 2x5970's as they have been demonstrated equal to 2 x GTX285's in toms charts rather than inferior as the first chart i linked demonstrated.
So averaging the two benchmarks we'd expect to see a 15 higher score with 3x gtx 285's compared to 3 x 5870.
The point is GTX280's scale better, so it is surprising that Mars didn't at all in bit tech's benchmarks.
I'd say 2x overclocked 295's would probably beat 3x 285's, perhaps again by 15% (who knows) and would probably beat 2 x 5970's (for considerably less money and only in Crysis).
I would also say that with the 275's your getting the most bang for buck if you want to hang with the big boys.
If you go for cheaper cards your getting less performance for price if you go for more expensive cards the same is true.
I don't need anymore than 3x 275's as it's maxing out my televisions ability to display frame rates.
Message edited by Mpyra on 03-10-2010 at 09:48:53 PM
Reply to Mpyra
- 0 +
What resolution do you plan to game at?
Reply to nzaneb
- 0 +
The bit-tech benchmark you just linked, showed both minimum and average framerates.
Reply to Silvune
Mpyra you obviously have your mind made up, no one will change your mind, so just buy the cards already
- 0 +
You clicked on the page before my edit lol.
Reply to Mpyra
This is easily the most stupid argument ever and I think someone just wanted to start a troll fight.
2x 5870 spanks 3x 285 in Stalker: Clear Sky, easily.
My point is he's wanting cards that max a certain title, he already did the research.
Though, it makes me question why he even started a topic.
Methinks this thread needs to be locked.
*Post Edited because of posting problems, full post now*
Message edited by cscott_it on 03-10-2010 at 10:12:37 PM
Reply to cscott_it
- 0 +
I've stated that my mind has been made up for some time now, i have bought one of the cards, I'm deciding on a motherboard and a processor.
I'm defending my choice a little, but then again, that's because people are criticizing it.
People have their own views of hierarchies of graphics cards some are very brand bias like fan boys, others are contemporariness biased tech junkies, some are a balance of both and there are many other factors.
I just want my card to play Crysis at 60 FPS and i found that TriSLIed 275's would do this better than much more expensive ATI cards Crossfired, i think confounds some people lol.
I stay in this thread out of interest, it's original purpose dissolved long ago.
Peace
Message edited by Mpyra on 03-10-2010 at 10:10:45 PM
Reply to Mpyra
Couldn't agree more, needs to be locked.
- 0 +
An i7 at 4ghz will bottleneck 3 - GTX275's at anything less than 1900x1200. I really hope you have high resolution capabilities. The 1366 platform is really the only logical choice for Tri-SLI.
Reply to nzaneb
- 0 +
You need to listen, not jump to conclusions.
There is only one reason why nVidia tended to do better than ATI in Crysis, and its not drivers as both companies have been optimizing the drivers for years now. Its the texture units. The engine that Crysis is built on uses old tech, tech that we were trying to do away with after DX8. Crysis loves Texture units, and nVidia has had more of those than ATI for a long time. This is why nVidia tended to do better in Crysis while being very close else where. However, the 5xxx series has the same amount of texture units as the GTX 275, 80 TUs. This means that there is no nvidia optimization in this context.
Also, let me be perfectly blunt here. If you buy 3 GTX 275s over 2 5870s because of the performance in the 3 year old game, Crysis, your being incredibly stupid. The game is old, the multiplayer average at best, and the graphics are soon to be surpassed. Not only that but look here:
http://tpucdn.com/reviews/ATI/Rade [...] 0_1200.gif
As you can see, at 1920x1200, dual 5870s max out Crysis very well, meaning you will get no tangible improvements with 3 GTX 275s.
What will you get with 3 GTX 275s then? You may save a bit of money. Now, what will you get with 2 5870s for slightly more? You get the same performance in DX9/10, lower power consumption, better performance in future titles with DX11, better graphics in future titles with DX11, eyefinity, cooler temps, the ability to add another later, the ability to play any game, including Crysis, maxed with good FPS, the ability to make the price difference negligible because of PSU prices, and the ability to actually save money over the Tri GTX 275 system by going the Phenom II route, which won't give you any less performance in gaming than the i7.
There is no reason to get the Tri SLI GTX 275s. If you choose that route, know at least what you will be missing.
Message edited by AMW1011 on 03-10-2010 at 10:28:06 PM
Reply to AMW1011
- 0 +
I was just wondering this.
I am trying to decide between AMD Phenom II X4 955, Intel Q9550 and i7 920.
I've read the Q9550 overclocks to 4 Ghz on air, here's a video of it overclocked to 4.0 Ghz on a 790i FTW.
http://www.youtube.com/watch?v=FglPhsStqKg
I'm just starting to look into what the others are capable of.
I can get the 790i FTW for £50.
1366 Mobo's would probably cost £100-150, as for the processor itself i need to look into that a little more.
Could the Q9550 overclocked perform as well as a i7 overclocked??
Reply to Mpyra
Peace
If that's case let's end it here, if that's a problem then PM me.
[:thegreatgrapeape:7]
Message edited by Mousemonkey on 03-10-2010 at 10:38:50 PM
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1979 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Graphics Card Help for a Casual
By geofelt, 57 minutes ago:
As a standard, a pci-e x16 graphics card slot can deliver up to 75w to a graphics card...
Best offers
Top experts
