Cou cooler fan plugged into sys_fan instead of cpu
Last response: in Components
- SolvedCan I plug h80i water cooler into cpu opt and sys_fan1/sys_fan2? Forum
- SolvedWhat fan header do I plug my cpu cooler pump into Forum
- SolvedAccidently Plugged 3-pin fan connector into pins 2-3-4 instead of 1-2-3 of 4-pin socket. System won't turn on. Forum
- I am installing a cooler master 120v cpu cooler to a MSI GD65 mb. How/where di I connect wires to mb. I know where fan plugs. Forum
- SolvedThe Motherboard Posts, but when I plug in sys_fan to the PSU, there is no Post. Forum
- SolvedMobo SYS_Fan Issue/CPU temperature Forum
- SolvedTrying to install a case fan for CPU ( Cant find sys fan 2 ) Forum
- SolvedLink between CPU temperature and SYS_FAN2 Forum
- Can i put a fan on my case which is meant to go in SYS Fan slots into a CPU OPT slot- which is meant for a water-cooling cpu? Forum
- SolvedComputer will only show images with CPU fan not plugged in. Forum
- CPU Fan slows to crawl when fully plugged in to 4 pin connector, normal speed when partially plugged in. Forum
- SolvedCPU Fan not plugged in Forum
- SolvedWill the P67 Sabertooth boot if you don't have a CPU_Fan plugged in? Forum
- SolvedCPU Liquid Cooler vs Aftermarket Fan Forum
- SolvedCPU-FAN Cooler Master Forum
- SolvedAdvice regarding removal of side fan to install CPU cooler... Forum
- SolvedBudget 4 Pin Fan for a CPU Cooler Forum
- SolvedA better CPU-Fan or Cooler for A4-5300 Forum
- SolvedCooler Master - Hyper 212 EVO 120mm CPU Cooling Fan Forum
- SolvedJust built a PC and it will not power on. When I push the power button, the CPU cooler fan begins to spin for just an instant Forum
- More resources
Read discussions in other Components categories
