Help with OCing 3770K, Corsair16gb1866mhz on Z77 sabertooth
Hi.
I'm hoping that someone can help me to overclock my 3770k and corsair 16gb memory on my z77 sabertooth.
I have little knowledge of Oc'ing.
I have H100 for cooling with 2 fans.
But i Iv bought 2 more hige performance fans from corsair that i will install a bit later for push pull for lower temps.
My goal is 4.5-4.7Ghz if possible.
I have set the multiplayer within AI suit Turbo Evo to 44 and left everything els untouched(auto)
While running prime 95 torture for 30min I get 4213.6Mhz with max temps on cores 1,2,3,4: 66, 68, 71, 63c.
Higest voltage was 1.221V
I assume the bios is the best way to oc from her on out?
Im using HW info 64 as monitor for temps etc.
Can any one provide settings for higer oc?
Thanks a lot for your help.
1 answer Last reply
More about help ocing 3770k corsair16gb1866mhz sabertooth
  1. check out this thread you'll probably find what you need in there
    http://www.tomshardware.co.uk/forum/277215-11-intel-overclocking-club
Sabertooth Corsair Overclocking
