Hey guys,
So. I plan on venturing into the territory of water cooling soon, and I need a little advice. First, I want to let you know my plans to get started. I will be cooling a i7 930 (@4ghx) and a reference GTX 680 with this loop in a HAF X case. I plan (at first at least - I may add a 120 rad at a later date if needed) doing this with a single rad and pump and a push-pull set-up. I plan to purchase a "EK-KIT H3O - Supreme HFX 360 Water Cooling Kit" to do this. I think this is a good starting point for me to get into water cooling, as it is cheap and has almost everything I need to get the job done. From reviews, it also looks like a very solid kit. I will also be buying an EK 680 block, coolant, and (2) compression fittings to go with this (please see links below). Here's are my questions:
1. Am I missing anything? Is there anything else I should purchase to get the job done? More tubing possibly (in case I make mistakes)?
2. Does this look like an OK loop rout for what I want to accomplish? If not, please feel free to make suggestions. I am going for the most clean and good looking loop I can achieve.
3. Do I only need one bottle of coolant?
Thank you for any response! I really appreciate it!
EK kit: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=33430
680 block: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=35784:a8f3b08c668599ebde6993a8439314bb
barb fittings: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=28402
coolant: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=32224
