Solved
Gigabyte 3D Galaxy II Water Cooling System fit in antec 900
Last response: in Components
WR2 said:
There are some issues with the Antec 900 and that water cooling kit.
If you check the NewEgg customer comments and search on the Antec 900 you'll find what the 900 owners are saying:
http://www.newegg.com/Product/ProductReview.aspx?Item=N...
"If you have a antec 900 and you have a dremal, a drill, and a handfull of time, have fun"
http://img203.imageshack.us/img203/3949/ss034.jpg
ahk thanks dude so do you reckon its better off goign with the cosair h50?
I actually think you'd be better off with one of the better aircoolers.
Thermaltake Frio, Tuniq Tower 120 Extreme, Spire Thermax Eclipse II, Akasa Nero S or Titan TTC-NK85TZ Fenrir all cool equally well or better than Corsair H50, cost less and are easier to install.
really ahk well ill check them out thanks man
Ask the community
