The below is what I posted in my build thread, but I figured this issue needed some more advice so I made a thread here about it. For Pictures of my CPU only loop, visit page 3 of this thread and scroll down (Which has been my build thread): http://www.tomshardware.com/forum/page-377755_31_100.html
"I'm a little worried, actually a lot worried that I am not getting any flow of water past the radiator outlet. I can feel the water being pushed from the Pump into the Rad when I hold the tube firmly, but from the Rad to the CPU and the CPU back to the Res it seems like there is no water in there. I can't feel it by touch when I hold it firmly, I don't feel the flow. And also the tube itself just seems to be too light and flimsy and not rigid like it would be if it was filled with water (For example my drain line and tube from pump to rad is more rigid feeling). Something doesn't seem right to me here. It's as if the water is getting blocked in the Radiator some how. Could a massive air pocket in the rad cause a complete restriction in flow? Since the radiator currently is the highest point of the system, after work today I plan to turn the whole case upside down which would then make the rad the lowest point of the system and hopefully if there is air in there it would all burb out.
I could be wrong, maybe the flow of water past the radiator can't be felt. But just the way the tube feels flimsy and not rigid raised a red flag to me last night. I'll try to turn the case upside and see what happens.
If not, then I don't know what I can do outside of buying a flow meter and installing it inbetween the block and res (end of the loop) to see if I am getting sufficient flow. I guess if anything that would give me some piece of mind but damnit it would be so frustrating to have to unstall the whole thing again and have to reinstall it"
I copy/pasted the above from my original post into here for additional help.
It's also worth noting I have done numerous flushes of the system, so I could have built up a lot of air in the rad? Also, before installing the rad I did flush it with hot water until everything was clear. I don't think there could possibly be a solid obsruction, my only idea is it could be massive air pocket? Is that possible? Has it happened before? Is it common?
Any help would be appreciated.
Thank you,
EDIT: BTW, first time water cooler here.
Thank you,
