Solved
Does installing 2nd HDD consumes power when not being used?
Can you let me know about if I install and connect a 2nd HDD with no OS, does it still consume power when not being used at all?
2 answers Last reply Best Answer
More about does installing consumes power used
  1. This will depend on your power settings. It will consume a minimum amount if you spin it down when it's idle.
  2. Best answer
    Anything installed in a computer will draw some amount of power whether it is being used or not. An idling hard drive will consume a little bit of power. The only way to ensure it does not draw any power what-so-ever is to disconnect the hard drive's power cord. Not recommended while the computer is on.
Hard Drives Connection Power Storage
