Can no longer connect to wireless network even though signal is excellent
Last response: in Wireless Networking
Anonymous
April 25, 2010 5:27:33 AM
Hello,
I'm using windows 7 on my laptop & I've connected to our home network/internet before. However, now when I select the network & put in the password, it keeps telling me it can't connect to the network [even though the signal is excellent]. When I run the trouble shooter it tells e there is a problem with wireless adapter or access point.
I don't understand why I could connect before but not now?
Anonymous
April 25, 2010 7:56:27 AM
Is your router's SSID (broadcast name) the factory default (like Netgear or Linksys) ? If so you may be trying to connect to a neighbour in error and should change the router SSID to something unique.
Before getting into more complex solutions just try disabling wireless security in the router temporarily -- if the system then works you know where the issue lies.
m
l
