I build a PC for my dad and right away at boot up the screen says no hard drive is detected. I know it is detecting a hard drive because it goes through the rest of the boot and then you can use the computer and windows starts and all of his programs are there. So not sure why it says it can't detect the hard drive but then I can still use it. I bought almost all the same parts for my PC and it is doing the same thing.
I don't believe it is the hard drive because they are different brands and sizes and everything. I think I just have the hard drive plugged in to the wrong spot. Although not wrong enough to stop it from working.
It isn't the end of the world but is very annoying that my day old PC is already giving me an error and would like to figure out the problem. If you have any ideas I would appreciate the help.
The motherboard is P7P55D-E PRO and our hard drives are both sata.
Thank you.
Thank you.
