I am planning to order these parts form newegg.ca. Can you tell me if the parts are compatible and if I should switch any parts? Also, any general tips when building this computer? Finally, will the power supply handle electricity from 220v or will it only work in areas with 110 volts?
Parts: http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119161
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136098
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813138182
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814131327
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817341019
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231277
http://www.newegg.ca/Product/ComboDealDetails.aspx?ItemList=Combo.298282
Thanks in advance for your help!
