Solved
Global sound mixer to fix treble/bass for all programs?
Last response: in Windows 7
Not as part of Windows 7, if you have an addin sound card with software, or your motherboard supplies such software for onboard sound. Otherwise get better speakers with their own controls, which would be best option.
When I did the fresh OS install with Win 7 64 it just applied a standard "high definition audio" driver.
Wonder if I could get a driver update from Intel for their G33 board.
Only concern is that it's a driver that seems to control the integrated audio/video. Not sure I want to mess with that and risk things getting messed up with my graphics card.
Best solution
To turn down the bass do as follows;
Right click on speaker icon, next to the time.
Select Playback devices,
Right click on speakers
Select Properties
then select Enhancements tab,
tick Bass Boost
Then select Settings at the bottom
From here you can turn down or up the Bass.
Click OK, Apply. Ok.
Ask the community
