Closed
Power supply unit
Graphics card Authority
digvijaysingh said:
Please some one tell me whether I should buy HD 5770 or HD 5670.
My PSU is 450 watt.
I am worried whether My PSU will support both card.
Depends on the brand. Tell us the name.
either card will work with that PSU, although as hallowed_dragon said you need a good brand of PSU (not to run the cards, but to avoid PSU problems)
also, get the 5770, it is so much better, you will be glad you did.
Related ressources
Graphics card Master
A 5670 would be fine, but I'm wondering whether the 5770 would work properly even though your PSU meets the requirements.Post your other specs so that I can have a better idea.
AC I/P - 115/230 V
DC + 3 .3 N/ + 6
D/P 25 A/24 A
60/50 HZ
-12 V/-5 USB
0.8 A/ZA
+ 12 V
16 A
-5 V
0.3 A
Power supply Expert
That would be an overkill for just 1 HD5770, but if you want to CF them then that's okay, go for that... :)
Ask the community
