Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Laptops and power from usb port
Forum Laptops & Notebooks : General Laptops & Notebooks - Laptops and power from usb port
Archived from groups: comp.sys.laptops (More info?)
I've been reading reviews on the Compaq NC8000 when I found this article:
http://reviews-zdnet.com.com/HP_Co [...] 4-3121_16-
30583495.html
.... that says the unit doesn't supply USB bus power. How common is that
among laptops... I can't find an answer in google searches. It seems like
it would be a pain to have to lug around power supplies for each peripheral
and might be a big pain. Or maybe usb hubs are powered and it would just be
one extra power supply?
Any input appreciated =)
Sponsored Links
"Indrid Cold" <nobody@nospam.com> wrote in message
news:7tM%c.6222$5Y6.2546@trnddc07...
| 30583495.html
peripheral
be
I can't speak for "most" by any means, nor on that specific model. I do know
all I have owned and worked with have had powered USB ports. I know that
doesn't help much, but just my experience.
Reply to Anonymous
Many laptops can & do provide power via USB ports:
o Current capability is limited - typically 500ma
o Some peripherals plug into 2 ports - to distribute power demands
o Current draw limit is by a resettable fuse IIRC - on some by failure
I have connected USB-powered devices to a USB port, and after a
time have found they have cut-out requiring time to "reset". This was
most common with a USB-powered CanoScan Lide 20 - a very cheap
but also surprisingly high quality scanner, lightweight, like a laptop.
Some laptops deliver power via the PS/2 port (if fitted), which can
be used to boost power. However, realise that USB ports in general
are low power output devices - an external powered hub is advised
if you have more than one device, particularly if self-powered.
Power output via the PS/2 ports can be limited too - KVM switches
often do not work with laptops without an add-on powersupply.
So it comes down to...
o Exactly what device you wish to power
o Whether the USB ports provide power, and how much
The CanoScan LIDE 20 supposedly draws 500ma, and the Inspiron
1100 laptop supposedly can supply 500ma. Even so, I could replicate a
power cut-out mid-scan through a run of consecutive scanning operations.
For serious use, a powered hub is A Good Idea just to be safe.
Dorothy Bradbury
www.stores.ebay.co.uk/panaflofan for quiet Panaflo fans & other items
www.dorothybradbury.co.uk (free delivery)
Reply to Anonymous
"Dorothy Bradbury" <dorothy.bradbury@ntlworld.com> wrote in message
news:O240d.163$2z2.67@newsfe3-win.ntli.net...
PS/2 ports have a 1 amp picofuse on the board (desktop and the few remaining
notebooks with PS/2 ports). Blow this fuse and that's the end of your PS/2
ports unless you're into taking things apart and soldering on a new fuse.
Current limiting on the PS/2 ports is a requirement of the safety agencies
(UL/CSA/VDE), since the power supply can provide copius amounts of +5V in
the event of a short on a device plugged into the PS/2 port.
Reply to Anonymous
There are 739 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
