D dh3 Distinguished Apr 20, 2010 19 0 18,520 Jun 8, 2010 #1 what is meant by ATX 12v 4 +4 because I will buy the power supply 650watt venomrx rd diamond but I use the 4 pin motherboard connector, while the red diamonds venomrx mnggunakan conncetor 8pin? if it can be work with my moyherboard? thx all,,
delluser1 Splendid Feb 22, 2007 6,261 0 26,460 Jun 8, 2010 #2 It means that you can use the connector for either a 4 pin ATX or 8 pin EPS/EATX motherboard connection. Upvote 0 Downvote
