Hello, I just started planning out all my parts and stuff i live in south long beach and do any of you guys know any good technicians that build systems? i heard ibuypower is good but ppl have probs with it so not sure and will this setup work?
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
intel Core i7: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202&cm_re=intel_i7-_-19-115-202-_-Product
DVD drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
Antec 900: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021&cm_re=antec_900-_-11-129-021-_-Product
HD 5850: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161302&cm_re=5850-_-14-161-302-_-Product
Memory http://www.newegg.com/Product/Product.aspx?Item=N82E16820227289
I don't know what ram i should get kinda new to building systems ! and what sound card do you guys recommend something not to expensive i have a limit of 1800$ of building my system so please help guys! any recommendation for different parts that are better or more compatible with each other i would really appreciate thanx guys!
