APPROXIMATE PURCHASE DATE: April 7th
BUDGET RANGE: <900$ Before Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, General Use.
PARTS NOT REQUIRED: Video Card (Gigabyte GTX 260 SO), HDD(Samsung F3), Wireless PCI Adapter (D-Link DWA522), Monitor(23"LG 2MS), Keyboard(Logitek Illuminated), Mouse(Razor DeathAdder3500), Speakers(Altec Lansing), MousePad(Razor eXactMat).
PREFERRED WEBSITE(S) FOR PARTS: newegg.com or cheaper
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: N/A.
OVERCLOCKING: Maybe, SLI OR CROSSFIRE: Maybe Later
MONITOR RESOLUTION: Mine does 1080P 1920x1080
ADDITIONAL COMMENTS: Best for the money xD
So I only need CPU, MB, Case, PSU, RAM, CPU Cooler. Is the CPU coming with thermal paste?
Here is what I did today, I am opened for any suggestions/comments/etc:
COOLER MASTER Storm Scout SGC-2000-KKN1-GP Black Steel / Plastic ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196
OCZ ModXStream Pro OCZ700MXSP 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341018
Intel Core i7-920 Bloomfield 2.66GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
ASRock X58 Extreme LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157163
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227478
XIGMATEK Intel Core i7 compatible Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
Total with shipping to 92122 I get $932.51
I need lower $$$ and better components xD.
AMD system would be OK ?! but I don't know how it is in comparison with i7 system and components I already have.
Thank you.
Thank you.
