Solved
First ever built need help
Last response: in Systems
March 30, 2010 5:42:14 AM
APPROXIMATE PURCHASE DATE: Next few days
BUDGET RANGE: $700
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: multitasking, Internet, music, burning, photoshop
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers
PREFERRED WEBSITE(S) FOR PARTS:newegg.com
PARTS PREFERENCES: Amd
OVERCLOCKING: not yet
MONITOR RESOLUTION: 1680x1050,
ADDITIONAL COMMENTS: Just want a quick reliable pc. No gaming. will use the video and sound off the motherboard until I find a gpu I want. Thanks for the help
OCZ ModXStream Pro OCZ500MXSP 500W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7 - Retail
AMD Athlon II X4 630 Propus 2.8GHz 4 x 512KB L2 Cache Socket AM3 95W Quad-Core Processor - Retail
Antec TWO HUNDRED S Black ATX Mid Tower Computer Case - Retail
ASUS M4A785TD-V EVO AM3 AMD 785G HDMI ATX AMD Motherboard - Retail
Patriot G Series ‘Sector 5’ Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model PGV34G1333ELK - Retail
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Sony Optiarc Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD/CD Rewritable Drive - OEM
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
Arctic Silver 5 Thermal Compound - OEM
Subtotal: $644.90
Grand Total: $701.09 With tax and shipping
Total $666.09 After mail in rebates
More about : built
Best solution
March 30, 2010 5:54:02 AM
Some changes and combos...
RAM + Mobo
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
DVD + PSU
HDD - Maybe the 1TB Samsung F3 ?Its faster than the 640GB Black
Thermal compound -
March 30, 2010 6:08:00 AM
^ Yes...the rest are very good choices...
m
l
March 30, 2010 6:13:07 AM
Best answer selected by ryanthedoc.
m
l
March 30, 2010 6:14:28 AM
Thanks again I appreciate it
m
l
March 30, 2010 6:15:31 AM
Glad I could help...
m
l
March 30, 2010 6:23:00 AM
Do you think it would be worth the money to swap the athlon IIx4 630 for the Phenom II X4 925 Deneb. $40.00 difference
m
l
