Could this problem be Ethernet port on the motherboard
i am running a asus M4A78LT-M LE Socket AM3 AMD 780L mATX motherboard (only had it 3 weeks) linksys wireless router with wifes pc and mine both hardwired to the router.
problem is that my internet connection once to 3-times a day keeps going off for no reason and the wifes internet is ok and stops on been like this for last week or so ,only time i can get back on his by rebooting my pc now i changed the Ethernet cables about 2-3 times and it still happens for some reason my internet don't work but the wifes does , i powered off the modem and the router few times and still the same reset router as well a few times and still knocks off 1-3 times a day.
now could this be a the Ethernet port on the motherboard where my cable goes to back of pc this is only thing i can think of that its not working right .
or is it something else appreciated any answers ty .
3 answers Last reply
More about could problem ethernet port motherboard
  1. If you have a Static IP within the DHCP range then you can easily have this problem.
    Q - Is anything static IP {Network Printer, Phone, etc}?
    If yes then refer to the following example:
    DHCP 192.168.1.2~192.168.1.100
    Static 192.168.1.101~192.168.1.255
  2. no i am with comcast and i think thats dynamic IP address
    and no i got nothing else on the router only 2 hard wire pcs mine and the wifes
    since did this post it had done it agion today had to reboot pc :(
  3. The rule-out a corrupt NIC registry; open the Device Manager expand the [+] Network adapters, right-click and select Uninstall then reboot. If that fails go to ASUS's website and D/L the most up to date NIC drive and reinstall.
Motherboards Routers Ethernet Card
