Graphics Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150462
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813138163
I recently put together a new PC. Everything has been going great...except my video card. I was first tipped off when I tried to play bad company and was getting awful awful fps when I read reviews that said the card played it great.
I went to device managers---->display adapters and it displayed a "Radeon 3300 Graphics Series". That is the on-board graphics from the motherboard.
I put in the CD that came with the card and it gave me an error saying there were, "No XFX products installed on this computer". Then, I installed Catalyst 10.2 manually from the ATI website.
When all that didn't work, I went into my BIOS and disabled the onboard video card. I tried 3 different monitors and 2 different HMDI cables and all I got was, "No Input Signal". That created a situation where my monitors wouldn't work without on board graphics going, but my on-board graphics couldn't get turned on because I couldn't see BIOS on my monitors. I reset my BIOS by reading through the manual and finding a process to reset my CMOS.
Now, my monitor works again but the computer is still not reading my Card. XFX provided an HDMI to DVI adapter...but when I used that and plugged it into a slot where my graphics card was located it didn't read anything. I am about to try to disable on-board again and retry the DVI, but I have no idea if it will work.
I'm pretty frustrated, can't think of what else to do. Any suggestions or ideas?
I also can't find an update for my BIOS, so if you can find one with a recent AMI update that would be great.
Thanks for all your help.
