When I hit power button, screen goes black PLS HELP
  • Configuration
  • Computers
  • Power
  • Windows 7
Last response: in Windows 7
December 22, 2009 8:47:01 PM
I am seriously at my limit spent 3 days I still cant figure it out, done probably 100 reboots.
Contacted ASUS Support they are useless still in contact with them in troubleshooting this matter.
This is my issue.
When I hit the Power Button my screen goes black, before a bios revision it would just reboot my computer.
YES I have set Power Options, Power Button to shut down computer.
I noticed I am missing a Sleep Button Action as its not in my menus. Maybe this could be a leading reason why this is happening? Anyone know how to get this option to show up?
I have used another computer cases front panel and same issue occurs so it cannot be my front panel.
I have a gut feeling the OS ACPI is completely being ignored when it comes to what the Power Button should do, if I set it to Sleep/Hibernate/Shut Down SAME thing still occurs.
I have got the Power Button to work successfully maybe 8 times out of the 100. It actually Logged off, Saved Settings and Turned of Computer as what I am trying to get it to do.
I have reinstalled the ACPI driver from ASUS but nothing changed. Have the lastest BIOS Revision as well. I have removed battery and cleared CMOS as well. Also loaded default BIOS settings.
My System:
HAF 922
Phenom II 955
M4A79XTD EVO AM3
G Skill Ripjaws DDR3 1600
750GB WD Black Cavier
1TB Green Cavier
320GB Cavier
Logitech Illuminated Keyboard (Maybe can use ACPI I think dont know if it can conflict?)
Weird thing, guy at ASUS told me to set it to "S1 Only" in BIOS and it actually worked twice, third time I hit the power button it went back to same behavior.
I noticed my chances are higher for it to turn off properly when the power options advanced settings window is open for some reason...
I hope someone knows how to fix this.
Thanks In Advance.
More about : hit power button screen black pls
a c 215 $ Windows 7
December 22, 2009 11:05:33 PM
Perhaps try re-flashing your BIOS back to that old version that didn't have this problem? Did you flash it to the latest version for a particular reason?
m
l
December 22, 2009 11:42:51 PM
It never worked, first thing I did when I built the PC was update BIOS.
Perhaps Ill try an earlier BIOS version.
Any other ideas?
m
l
a c 215 $ Windows 7
December 22, 2009 11:50:11 PM
If the earlier BIOS versions don't work, I'll take a shot in the dark and say your board may be defective? I'm not really sure what to make of this issue right now though... definitely got me scratching my head.
m
l
January 19, 2010 3:52:01 AM
same issue here. must be BIOS needs fixing... Have to soft shut down & just use button to turn on 'til Asus fixes it.
m
l
