are these parts good and compatible for watercooling just the cpu
and how may I improve them
http://www.xoxide.com/xspc-twind5dualbay-reservoir.html
http://www.frozencpu.com/products/14366/ex-blc-1001/Swiftech_Apogee_HD_High_Performance_4-Port_CPU_Waterblock_-_White_-_Intel_w_LGA_2011_Hardware_AMD_Ready_Apogee-HD-WT.html
http://www.frozencpu.com/products/16947/ex-rad-433/Black_Ice_GTX_Xtreme_240_Radiator_-_Custom_Painted_White.html
http://www.frozencpu.com/products/17707/ex-liq-284/Mayhems_Pastel_Coolant_Concentrate_-_250mL_-_Ice_White.html
http://www.frozencpu.com/products/13474/koo-299/Koolance_38_x_12_10mm_x_13mm_G_14_Threaded_Compression_Nozzle_-_Black_NZL-V10-BK.html
http://www.frozencpu.com/products/17587/ex-tub-1575/PrimoChill_PrimoFlex_Advanced_LRT_Tubing_38ID_x_58_OD_-_10ft_Retail_Pack_-_Clear_PFLEXA10-58.html
thank you
thank you
