Help with 3770k and offset voltages
Hello. Iam a beginner in OC'ing and i need some help to OC my cpu. Im trying to OC my 3770k to 4.5 ghz with a asus p8z77-v motherboard. I think i found the cpu sweet spot using manual voltage. Its stable at fixed 1.255 at 4.5 ghz. So what i want to do is use the offset feature so that the cpu will drop its voltages while idle. If i leave it to offset and auto my voltages go up something like 1.37-1.4 volts. So im wondering if i can use offset but have 1.255 as a limit. I tried using offset with -sign. The value range from 0.005 to 0.65. Cant get it to boot with -0.065. If i use just 0.005 it doesnt do much on the voltages. Any help will be appreciated.
More about : 3770k offset voltages
seems to hang around 1.05. So what will i need to do? If is auto it makes the cpu volts really high. i want to use offset instead of manual. But after experimenting for a few days i dont think its possible. Once i set it to offset with -sign the max - offset is 0.065 on the asus board meaning it will drop it down to 1.31-1.32 in theory. Or maybe iam not doing it right? Maybe my LLC set to ultra high adds too much voltage???
