Sign-in / Sign-up
New System Build will this work?
  • New Build
  • CPUs
  • Hard Drives
  • Systems
  • Product
Last response: in Systems
April 1, 2010 2:57:25 PM
a b à CPUs
April 2, 2010 1:26:30 AM
Mobo/CPU combo link is broken - no longer available, repost the mobo and CPU.
m
l
a c 83 à CPUs
April 2, 2010 1:37:16 AM
Go with the Cooler Master Hyper 212+... Don't waste your money on the V8.
Your i7 930 MOBO combo is not available. I would look to get a MOBO with USB 3.0 & SATA 6.0 Gb/s support or... go with the faithful ASUS P6T Deluxe V2
m
l
April 2, 2010 4:59:50 AM
sorry bout that here is the MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
and the CPU http://www.newegg.com/Product/Product.aspx?Item=N82E168...
i think i am going to go with that CPU since i am going to overclock it will it make much difference with the 930? i am planning to overclock to 3.5GHZ if possible atleast 3.0
and with the cooler that tecmo suggested.
And with all this will my build work properly and stable?
m
l
April 2, 2010 5:01:43 AM
Ayyyy thanks buddy for all your help yea so im guna go with p6t and the cooler almost got enough money to get my parts :D  just seeing others opinions if my build will work :D
m
l
April 2, 2010 5:42:00 AM
thanx man i think ill go with the p6t and the 930 i really like the ASUS P6X58D (second link) i might consider checking it out and if i do is it a good motherboard for overclocking? im not guna overclock like insane just a nice 3.5GHZ to rip games apart :D  will that ASUS P6X58D read all my ram and is it easy for overclocking like the p6t? is stable like the p6t? thanx!
m
l
a c 83 à CPUs
April 2, 2010 11:03:32 AM
Yes... To all Three questions from what I've seen :)
m
l
a b à CPUs
April 2, 2010 11:18:59 AM
and the p6x58d has usb 3.0 and sata 6gb/s
m
l
April 2, 2010 9:45:17 PM
thanx tecmo! excellent advise like always! :D
m
l
April 2, 2010 9:45:44 PM
yup yup so ill go with that mobo :D
m
l
April 2, 2010 11:42:19 PM
thanx for all the replies! so my final question to all of you guys is if with all these components will my build work stable,perfectly, and destroy games with a decent overclock!? thanks!
m
l
a c 83 à CPUs
April 3, 2010 12:07:14 AM
It will run stable and destroy most games depending on resolution. It will be a sweet system & down the road when you purchase another 5850 for your system, even better :)
m
l
April 3, 2010 6:59:34 AM
thanx man u da best! and by the way im guna run at 1400 x 900 screen resolution :D  thanx again for all the help!
m
l
