I am going to try to be specific as possible as this is a bit strange. First when I start up my computer will continuously turn on and off 5-8 times but then after that and every other time after I reboot it will boot to the bios without any trouble. I will then proceed to boot into the OS but after about a certain amount of time the computer will freeze and I mean completly freeze the mouse and keyboard are unresponsive. I just built this computer and I would think if it was a power supply was malfunctioning the computer would just shut off like at the beginning instead of displaying everything on screen. It could be my motherboard too though because my case has letters labeling all of the necicary places to install risers but my motherboard must have been slightly different because one riser did not show and when I became aware of this I thought the motherboard was shorting out so I took the motherboard out installed the riser but the problem has not yet been resolved. Did not putting in the riser permanently damage the motherboard or do you think its a faulty power supply?
