Gateway sx2800 power supply upgrade
Hello forum,
I know there a bunch of threads on this topic - I've read them all. Has there been a solution to the ps upgrade?
Mine went bad and instead of sending off to Gateway to be replaced, I'd rather upgrade it above 220W myself. Has anyone done a successful upgrade in this slimline case?
For those that don't know, the dimensions on the current ps are:
8.9 x 3.6 x 2.1 and it's 220W
2 answers Last reply
More about gateway sx2800 power supply upgrade
  1. enzo matrix said:
    These look like the size of your PSU:
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010090058%201131349608&name=Mini%20ITX
    Might be what you are after.
    What did you end up getting? Just curious as I have a 2800-3 and want to upgrade the Power.
Power Supplies Gateway Components
