Hi all,
I am about to order my PC. Could you please check this out and see if everything is compatible?
I don't want to mod my case.
Case: NZXT Switch 810
Watercooling 1 CPU and 1 GPU:
Watercooling Components:
Watercool HEATKILLER GPU Backplate GTX680
PrimoFlex Advanced LRT Tubing - 3/8in. ID X 1/2in. OD - Bloodshed Red
Aquacomputer AquagraFX for GTX 680 G1/4, Nickel Plated Version
XSPC Raystorm CPU Waterblock - Intel - Chrome
- Fitting Size 3/8" Barb for 3/8" ID tube
Alphacool NexXxoS UT60 Full Copper 420mm
XSPC RX240 Extreme Performance Radiator Version 2
- Nozzles No Nozzles
Bitspower Ultimate G 1/4 Thread 3/8" ID x 1/2" OD Compression Fittings
MCP655
MCRES Micro Rev2 Reservoir
PC Specs:
3930k
680
Does this look fine?
Thanks.
MCP655
PC Specs:
3930k
680
Thanks.
