goalguy876 Distinguished May 29, 2010 268 0 18,810 Jun 11, 2010 #1 I need two fans that will work with this controller off of newegg. Blue LED's would be great
Solution Pyroflea Jun 12, 2010 goalguy876 : So what fans would that be? Would an apevia 120mm blue led fan work? Any fan with a 3-pin or molex connector. The Apevia fan appears to have a 4-pin connector (the one's I'm looking at at least). http://www.newegg.ca/Product/Product.aspx?Item=N82E16835200049 http://www.newegg.ca/Product/Product.aspx?Item=N82E16835132008 Either of those would work.
Pyroflea Distinguished Mar 18, 2007 2,156 0 19,960 Jun 12, 2010 #2 3-Pin Fan Connectors as well as 4-Pin Molex Connectors are included on this unit, IIRC. Upvote 0 Downvote
goalguy876 Distinguished May 29, 2010 268 0 18,810 Jun 12, 2010 #3 So what fans would that be? Would an apevia 120mm blue led fan work? Upvote 0 Downvote
Pyroflea Distinguished Mar 18, 2007 2,156 0 19,960 Jun 12, 2010 Solution #4 goalguy876 : So what fans would that be? Would an apevia 120mm blue led fan work? Any fan with a 3-pin or molex connector. The Apevia fan appears to have a 4-pin connector (the one's I'm looking at at least). http://www.newegg.ca/Product/Product.aspx?Item=N82E16835200049 http://www.newegg.ca/Product/Product.aspx?Item=N82E16835132008 Either of those would work. Upvote 0 Downvote Solution
goalguy876 Distinguished May 29, 2010 268 0 18,810 Jun 12, 2010 #5 Best answer selected by goalguy876. Upvote 0 Downvote
