Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > Best sound card for movies
Forum CPU & Components : Sound Cards Best sound card for movies
Hi
What's a good sound card for movies? I need to connect with my pc to my home cinema digital receiver. Thanks
Reply to Charlezman
A sound card is not required if you use a HDMI cable to connect your PC to your receiver.
Reply to WR2
Yes I know, but I want a better sound coming out from my pc cause when I see a movie from my home dvd the sound is much better so I though that if I buy a sound card my pc sound will get better. At the moment I am connected trough coaxial cable from an on board card.
Reply to Charlezman
- 0 +
theres very little difference if your passing the audio thorugh digital....
Reply to MEgamer
No doubt the sound card will improve audio quality. People think there's very little difference & that sound card is just a waste of money (when onboard sound serves you rather well), but trust me, once you hear w/ a sound card attached, the expense seems totally worth it. Also the sound card frees up the CPU to dedicate itself to pure data processing rather than also have an additional audio overlay.
The Creative X-Fi titanium is a good one. You could also get the Fata1ty version if possible.
Reply to ksampanna
- 0 +
Your home theater speakers are:
(1) Attached to your digital receiver? (home audio speakers)
(2) Attached to your PC? (PC speakers)
Reply to WR2
I have 5 b&W speakers + yamaha sub woofer. Front main are big floor standing 200w the others center and surround are smaller hang on speakers 100w. The sub woofer is 100w everything is attached to my home receiver
Message quoted 1 times
Message edited by Charlezman on 06-12-2010 at 09:17:04 PM
Reply to Charlezman
- 0 +
dude if its dgital... there is no or absolutely tiny difference.... its passing the raw signal that was barely processed or not at all.... this guy is talking about passing to the receiver... if u have an amplifier at home, then im sure you'd understand that there is barely perceptible difference when passing digital signals, the only difference you would mostly be able to tell, would be the reasons of using bad wires.
we are not talking about analogue here.....
and yes i know theres a diff in audio cards (analogue > digital)....
and creative isnt as gd as ASUS or Auzentech or HT omega//, quality is better on these cards, oh and the price.
Message edited by MEgamer on 06-13-2010 at 12:30:01 AM
Reply to MEgamer
- 0 +
if you want to have gd sound quality, use your SPDIF, or Co-ax, HDMI from your motherboard to your receiver, if you have one. And invest in a gd Monster digital cable.
Reply to MEgamer
- 0 +
I was thinking of suggesting a HD 5450 video card instead of sound card.
Radeon HD 5450 512MB DDR3 Video Card Review
Charlezman;
Can you describe your HTPC components for us?
Reply to WR2
Thanks dude, that's an interesting idea, I'll be catching 2 birds with 1 stone, better sound and a gc upgrade and as I am into a quite pc this card seams to have everything I need its passive so no noise, consumes few power so its good for my fanless psu and its not expensive. I will give it a serious thought
I have a pioneer receiver, nvidia 7300gt with dvi out asus mb and an infocus projector
Reply to Charlezman
If I buy this card how am I going to connect the sound to my receiver? There is no coaxial or optical out in this card and my receiver doesn't have hdmi.
Reply to Charlezman
- 0 +
then there is no way, use the digital connection from your mobo
Reply to MEgamer
- 0 +
That complicates things a bit.
But I think a HD 4350 with S-Video is still an option.
Better video decode and HD audio options I think.
Reply to WR2
- 0 +
well s-video connection doesnt carry audio signals.
anyway i dont really see the reason why the OP wont just use the mobo , has he not got one???
Reply to MEgamer
If you use a Digital output, there will be close to no difference in audio quality between an onboard chipset and soundcard, so if your mobo has a digital output port, just use that.
If not, then all you really need is a cheap soundcard [preferably with DDL/DTS-C support, in case you want 5.1 for more then just movies], such as the ASUS Xonar DS, ASUS Xonar D1/DX, or HT Omega Striker.
------------------------------ http://valid.canardpc.com/cache/banner/1647132.png
Reply to gamerk316
Yes I am using digital out. Could it be the software? I am watch movies with wmp or vlc
Reply to Charlezman
- 0 +
what do you mean by could it be the software?
Reply to MEgamer
I play movies using wmp or vlc those are software no, maybe there are other software that can produce better sound than these two
Reply to Charlezman
Onboard HDMI ports don't support MCPCM or HD compression formats, just 2 channel PCM.
The only sound card that does MCPCM and HD compressed is the Asus HDAV 1.3.
Reply to astrallite
- 0 +
Since the OP doesn't have his speakers connected to the computer the uncompressed MC PCM isn't important to him, correct?
The HD 5450 and it's HDMI ver 1.3 support for Dolby TrueHD and DTS-HD Master Audio (MA) would have been an easy, inexpensive way to get the compressed audio bit-stream to the OP's receiver for unpacking.
Reply to WR2
- 0 +
why not use optical on his mobo? or does he not have one?
Reply to MEgamer
Asus Xonar DS is the best sound card.
Reply to ricky_critic
If his speakers aren't connected to the computer, how the hell is he gonna get Dolby TrueHD or DTS-HD? Magic?
Reply to astrallite
- 0 +
lmao!!!! this just aint working...
Reply to MEgamer
- 1 +
but he does have a receiver :D
Reply to MEgamer
I think WR2 doesn't understand the difference between bitstream and linear PCM. The former is compressed and requires decoding on the other end, the latter is uncompressed and requires no decoding, and both are hdmi digital formats.
He also states that you can avoid using a sound card by using onboard hdmi, but this is incorrect. The onboard chipsets, only have 2 channel PCM functionality, as they lack hardware acceleration.
The first soundcards to support multichannel (linear) pcm was the ATI 5xxx series, and the only ones that can do linear pcm AND bitstream is the HDAV 1.3. For movies with hd codecs you absolutely need the asus hdav 1.3, since only the oldest blu ray movies had uncompressed audio, and no other card can do bitstreaming right now.
Message edited by astrallite on 06-18-2010 at 01:25:14 AM
Reply to astrallite
- 0 +
Did THG get it wrong when they said:
HTPC Use: Bitstreaming Encoded Dolby TrueHD and DTS-HD Master Audio
The Radeon HD 5450 is a silent passively-cooled low-power card with a half-height bezel option. All of these attributes are ideal for home theater PC duty. In addition, the card is able to bitstream high-def audio codecs to your compatible receiver over a protected audio path. This is the only $50 card with this ability (if you're not counting Intel's Clarkdale-based processors and H55/57 motherboards), and HTPC enthusiasts will undoubtedly gravitate toward this card as a result.
Reply to WR2
Yes they did. Anybody who knows anything about blu ray playback knows this. That's why everyone is handcuffed to the HDAV 1.3 unless you want to rip your movies in multichannel FLAC.
Reply to astrallite
- 0 +
that is what i understand so far. arent u guys now mixing the same thing together. i think its teh little deatil to bitstreams and LINEAR PCM
just like ast. sed, ati 5 series and HDAV 1.3 are the only CARD so far, that can do 8 channel linear PCM am i right so far???
Reply to MEgamer
Gee, WR2, let me see, writing up your own code for some manual hacking that *may* work for some people, that really proves that it works.
Let me ask you WR2, do YOU have HD audio working? If so, please post an image of your receiver's front panel; it should be very easy since I'm obviously wrong. I've been struggling with ATI 4xxx and 5xxx series HDMI audio for years.
Message edited by astrallite on 06-20-2010 at 06:58:29 AM
Reply to astrallite
The problem is not the hardware, it's the software support obviously. All the HDMI interface is a digital bypass device, it relies entirely on software. Functionality can always be hacked in if you are a proficient programmer, but this doesn't really work for the majority of end users.
Reply to astrallite
There are 1718 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
CPU fan
By mocchan, 1 hour ago:
Your case has a cut out for a backplate to be installed, so you SHOULD be fine installing...
Best offers
Top experts
