I just put together my latest build it is a Rampage Extreme 3 by Asus. I am running an I7-950 Bloomfield 3.06Ghz.
My power supply is a 1000 watt ABS Dark Beret.
I have built many PCs in the past so im pretty confident all is set up correctly. When I started up my first boot, I did not hear any bios beeps at all my screen stayed black and was never able to access the bios. The LED for CPU on the mother board is a steady red. I was told it could be a CPU issue so I proceeded to remove the RAM to see if id get a beep if I got a beep I know the bios is being reached I did not get a beep at all. I even tried another power supply from my current PC and same problem. I inserted a speaker as well to be sure. All the fans light up and run, my case fans, cpu fan, vga fan everything seems to be getting power. Now I am just at a loss as to what else this possibly could be Does it sound like Motherboard issues or Power or CPU?
