Power Cable Question - plz help
so i ran out of power cables for the last fan in my case
the fans use molex (has both male and female)
my power supply has a 4 pin atx cable that coming out of the PSU (non modular), and has a 6 pin plug for a modular cable ready
my question is: If I use this - http://www.newegg.com/Product/Product.aspx?Item=N82E16812887001
will it work?
i ask because it says "Molex to 6Pin Adapter", so will it go both ways?
case is antech nine hundred if anyones wondering
1 answer Last reply
More about power cable question help
    Your case fans can be daisy chained together thanks to the "pass-thru" power connectors, and all run from 1 psu connector.
Motherboards Power Supplies Cable Power Product
