I'm planning to build a system with an Asus P8Z77-V (standard version) motherboard. I also plan to use an aftermarket CPU cooler. To be honest, I don't know which one, I'm not at all experienced in overclocking but its something I'm interested in doing on my new build. I was planning on setting up the PC first, then fitting the CPU cooler afterwards.
I am trying to decide on which RAM to buy. I know that I want 2x4GB DDR3 1600Mhz but I don't know whether I need to worry too much about it being low profile / height because of it blocking one of the CPU cooler's fans. The motherboard has 4 dual channel DIMM slots. I have read the mobo's manual and to exploit the dual channel capability I will need to use the 2nd closest slot and the furthest slot from the CPU. But basically the DIMM slot next to the CPU will be unoccupied.
So I would just like to know if with the motherboard / RAM configuration above, I am likely to block a large aftermarket CPU cooler if I use the RAM with the big heat spreaders (i.e. just for example, something like this)?
